Weekend on the Ck2510
   / Weekend on the Ck2510 #11
The rotary cutter is a 4' and I used it once so far. PSE, you have any other pics of that grapple? Is it bucket mounted? What do you use to control it? Looks good!
Yes it's bucket mounted, there are 3 bolts through the bucket on each side holding the main bar on. The grapple can be removed from the mounted bar with 3 bolts/pins and the hydraulic connectors. I control it with a diverter kit so when I press the trigger on the new joy stick it changes the curl function to grapple function. I also built a tooth bar for the bucket.
   / Weekend on the Ck2510 #12
Nice work! Any more info on the tooth bar? Those are some serious looking teeth on it.
Thanks,
E.
   / Weekend on the Ck2510 #13
Sweet action! I like it!
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2006 Suzuki GSX-R600 Motorcycle (A55853)
2006 Suzuki...
BUNDLE 4' X 5' EXPANDED METAL (A57192)
BUNDLE 4' X 5'...
Ford 655C 2WD Cab Backhoe (A57024)
Ford 655C 2WD Cab...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
