I thought using Stabil Marine would prevent this. How about running it dry each time? Thanks for the help.
Howdy,
A lot of factors come into play. Does the station which you got the gas from have any issues? Do they have a good turnover rate?
Gasoline does not stay good a long long time. The best approach is to siphon it out and rotate it through your vehicle.
Step 1
possibly find a station that sells 100% gasoline.
If not....
find a station which has good turnover and no water issues
Step 2
have a good clean gas can, put in your fuel stabilizer, fill gas can.
Step 3
fill your generator completely up. (full tank helps limit the amount of possible condensation)
Step 4
run your generator, and put a load on it. (at least 20 minutes)
Step 5
fill up the generator completely with gas. check the oil etc...
sit back and relax
remember to test run your generator every now and then.
at some point and time, drain out the gas, put into your car, and get new fresh gas with stabilizer again.
