Water in diesel
   / Water in diesel #11
water doesn't have to freeze to settle to the bottom. Water is heavier than Diesel even in it's liquid state.
   / Water in diesel #13
I was going to suggest mr funnel too, but you beat me to it. but your statement if about not adding water dispersants bothers me. I admit, I dont use mr funnel on my BX, but you got me thinking. what would happen to either cases .
I just researched a little on mr funnel and power service. on mr funnel website it says :Fuel additives and stabilizers may allow water to pass through filter. Add additives directly to tank. I always add PS to the tank anyways. To the OP - it might be a good idea to get a mr funnel if you havent used a additive yet in the can.
   / Water in diesel
Thanks everybody for the feedback. Dumped it into the truck today. It's got a water in fuel idiot light so I should at least get a warning. The last little bit was more clear than green, but not much in the grand scope of things.
   / Water in diesel #15
Better pack you a extra fuel filter in the glove box. I've seen a time or two when the light came on as it sputters to a halt!
   / Water in diesel
I know. Honestly, I think folks here are right that it was just not enough to matter--especially out of a 30 gallon tank. I'll be keeping my eyes open though.
   / Water in diesel #17
As mentioned, Mr funnel or its Racor rebranded equivalent.
Water in fuel is bad mojo. Most small tractors come with a pretty chinsy fuel filter. I wouldnt want to over tax it. And then there is the issue of freezing if you get too cold.
I have a Racor model 120 sitting in a box on the shelf waiting to go onto my BX. The factory filters are a joke.
   / Water in diesel #18
I too doubt there will be any issues but I'd rather have one with me than have to call someone to bring me one on the side of the road. I even keep a 19mm wrench in the door pocket to bleed the injectors should I need to.
   / Water in diesel
You know, come to think of it, maybe the time to dump questionable fuel into my truck's tank was NOT the night before I am going to be driving the trailer 120 miles one-way to take the pigs to the processor.
:duh:
   / Water in diesel #20
Correct. also the new 20,000psi common rail systems can suffer serious damage from water. (quickly too) Putting it into a newer truck would be the last place id put it. the tractor would be more tolerant of water than a new truck. (ignore if you have a 15 year old or older truck).
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
1981 Dorsey 24' Semi Dump Trailer (A57148)
1981 Dorsey 24'...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
