Water in diesel
   / Water in diesel #11
water doesn't have to freeze to settle to the bottom. Water is heavier than Diesel even in it's liquid state.
   / Water in diesel #13
I was going to suggest mr funnel too, but you beat me to it. but your statement if about not adding water dispersants bothers me. I admit, I dont use mr funnel on my BX, but you got me thinking. what would happen to either cases .
I just researched a little on mr funnel and power service. on mr funnel website it says :Fuel additives and stabilizers may allow water to pass through filter. Add additives directly to tank. I always add PS to the tank anyways. To the OP - it might be a good idea to get a mr funnel if you havent used a additive yet in the can.
   / Water in diesel
Thanks everybody for the feedback. Dumped it into the truck today. It's got a water in fuel idiot light so I should at least get a warning. The last little bit was more clear than green, but not much in the grand scope of things.
   / Water in diesel #15
Better pack you a extra fuel filter in the glove box. I've seen a time or two when the light came on as it sputters to a halt!
   / Water in diesel
I know. Honestly, I think folks here are right that it was just not enough to matter--especially out of a 30 gallon tank. I'll be keeping my eyes open though.
   / Water in diesel #17
As mentioned, Mr funnel or its Racor rebranded equivalent.
Water in fuel is bad mojo. Most small tractors come with a pretty chinsy fuel filter. I wouldnt want to over tax it. And then there is the issue of freezing if you get too cold.
I have a Racor model 120 sitting in a box on the shelf waiting to go onto my BX. The factory filters are a joke.
   / Water in diesel #18
I too doubt there will be any issues but I'd rather have one with me than have to call someone to bring me one on the side of the road. I even keep a 19mm wrench in the door pocket to bleed the injectors should I need to.
   / Water in diesel
You know, come to think of it, maybe the time to dump questionable fuel into my truck's tank was NOT the night before I am going to be driving the trailer 120 miles one-way to take the pigs to the processor.
:duh:
   / Water in diesel #20
Correct. also the new 20,000psi common rail systems can suffer serious damage from water. (quickly too) Putting it into a newer truck would be the last place id put it. the tractor would be more tolerant of water than a new truck. (ignore if you have a 15 year old or older truck).
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
2821 (A58376)
2821 (A58376)
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
