Want to add a split pipe on the fel for snow removal…what diameter?
   / Want to add a split pipe on the fel for snow removal…what diameter? #1
DonRina
Vancouver Island
Jinma 354
As the tag line says, I’d like to make a split pipe attachment for my fel so it doesn’t dig into my gravel driveway and surrounding grass when clearing snow this winter. I have some metal pipe lying around but wonder what diameter is best for this? Tried snow clearing without the pipe last year and it didn’t go well.
Don B
   / Want to add a split pipe on the fel for snow removal…what diameter? #2
I bought Edge Tammers about 3 years ago, they work great, very quick and easy to install or un install, no holes to drill, no welding, just a simple 3/4 inch wrench to install or remove them.
But it does seam like quite a few folks have done the pipe thing and report being happy with the results.
   / Want to add a split pipe on the fel for snow removal…what diameter? #3
I think the pipe idea is ok on a snow plow but do you mean putting it on the actual front loader bucket? If so that will probably be something you love part of the time and hate the other half of the time
   / Want to add a split pipe on the fel for snow removal…what diameter? #4
Also interested, as I want to do the same for my utv plow blade...
For my FEL, I use an Edge Tamer knockoff. (sorry ET)
ET design works great for when my gravel driveway isn't frozen yet. I would go with the ET.
   / Want to add a split pipe on the fel for snow removal…what diameter? #5
Never tried that, but if I did I'd try 2"ID SCH40. Slit it so it goes over the edge. Weld a tab on each end that bolts to the inside of the cheek of the FEL bucket with one bolt each.
   / Want to add a split pipe on the fel for snow removal…what diameter? #6
I have not used a pipe on a loader bucket before. For my ATV I use some 1-1/4" schedule 40. For the Meyers 7.5' blade on the tractor I use a 2" schedule 40. The heavier blade needs a larger diameter pipe.
   / Want to add a split pipe on the fel for snow removal…what diameter? #7
I've used same 2" steel pipe on both snow plow and tractor bucket - works fine
OK, based on the reply’s I’ll go with the 2” pipe. I’ll post a pic when made and installed.
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
2007 CHEVROLET Silverado (A56858)
2007 CHEVROLET...
V-HULL ALUMINUM BOAT (A52708)
V-HULL ALUMINUM...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2017 Chevrolet Silverado 3500 Ambulance (A55973)
2017 Chevrolet...
