WAM 1600T electrical problems
   / WAM 1600T electrical problems #1
9973720wb19
Platinum Member
East Coast
Many
I have a 2011 Wide Area Mower Turbo II.
1) signs of dead battery - installed new battery - all was well
2) same thing happened. June installed new battery - all was well (battery turned in read good)
3) yesterday, weak dash lights and alarm, would not turn over installed new battery - weak dash lights and would not crank - now when I turn the key nothing
I just noticed my manual states it should be a dry battery but I noticed the dealer sold me a wet battery would that make a difference? other than that, I think it must be some switch or short. I checked and cleaned all wires cables and ground along with a few safety switches
any help would be appreciated
   / WAM 1600T electrical problems #2
Do some measurements to see if you are drawing voltage from your battery when the ignition key is turned off. May help find the problem.
   / WAM 1600T electrical problems #3
Dry battery just means they are filled on site, a pre-filled wet battery is also just fine. Like mentioned above sound like you have a draw, when you installed the new battery did you see or hear any sparking activity when putting on the last bat cable. That can be a good indication that you have a draw...somewhere, if you don't have the tools to measure.
   / WAM 1600T electrical problems #4
I'd be checking your fan belt is tight. I fitted a battery terminal isolator to mine to prevent being powered up while not in use.
With engine at mowing revs battery should be at around 14.2v.
Platform/Catwalk (A50860)
Platform/Catwalk...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
Small concrete mixer (A49461)
Small concrete...
71069 (A49346)
71069 (A49346)
Off-Road Buggy (A50860)
Off-Road Buggy...
2016 BE Pressure PE-4013HWPAG Pressure Washer 4000 PSI Gas Cold Water (A48083)
2016 BE Pressure...
