Chipper Wallenstein BX40 Chipper Trouble - Shear Bolts, Clogged Chute, Rejected Feed
   / Wallenstein BX40 Chipper Trouble - Shear Bolts, Clogged Chute, Rejected Feed
Ok, so I said screw it, lets see how it runs. Reinstalled blades (correctly this time :duh:) and tested. It just ate a 3.5" chuck of oak like candy. Live and learn - thanks everyone!
   / Wallenstein BX40 Chipper Trouble - Shear Bolts, Clogged Chute, Rejected Feed #12
Good news, Sound like its working as it should. BTW, on the warped flywheel. My BX62s flywheel looks warped also if I check just the outer edge. However, if you check the blade/anvil clearance - the warp is down to less than a 64th of an inch.
If anyone is interested, through my local distributor, Wallenstein quoted about $950 for a new rotor. Made to order with a 2-3wk lead.
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
