W.R. Long 4in1 Photos
   / W.R. Long 4in1 Photos #1
Bill_in_MI
Rockford,Michigan
Kubota B7100, B2910
I finally got my camera. A while back I told some folks I would post a few photos of the HJ-2 60" bucket installed on my Kubota B2910. I'll send them up in successive posts with attachments. Let me know if you want to see any other views.
Bucket showing wear bar attached.
Bucket at back end showing splitting cylinder.
Shows the mounting of the solenoid valve. Later I plan to shorten the hoses a bit to tidy things up. Had to loop them as they are the original hoses that went to the steel cylinder tubes.
More plumbing. When I ordered the tractor in January I had them install a "3 position bucket dump" valve...special order from Kubota. It adds a second non-regenerative bucket dump position. The regen dump position is still maintained when the fel handle is in the extreme right position. In other words there are two dump positions right of "center" handle position. First is non-regen, second is regen (fast--but no power) dump. There is a detent that is pretty easy to feel between the two.
Last photo unless more requests (I err on the side of boring some, I am sure...but Long does not have a web site and I shure wished I could have seen a few more photos before I bought mine)
This is a shot of the optionl tooth bar. It may be confusing because it is laying across the top of the bucket. The steel bar the teeth are welded to 1/2" thick. As is the bottom side of the optional wear bar mounted on the front shown here.
   / W.R. Long 4in1 Photos #7
Very nice job with the photos, Bill. Thanks for going out of your way to provide detail on the product.
   / W.R. Long 4in1 Photos #8
Bill,
Thanks very much for your efforts. I'm interested in a 4-in-1 bucket, and this kind of info is invaluable - a perfect example of how useful this forum is.
Dave Wells
   / W.R. Long 4in1 Photos #9
Excellent photo spread, Bill. /w3tcompact/icons/smile.gif
Good quality pictures and a lot of information therein. Like Dave (Caretaker) says, you really add value to this message board.
I absolutely love your bucket, but even if I had the bucks I'm not sure if I would get one for myself. I seriously want the functionality you're getting with the 4-in-1, wear bar and tooth bar, but all of that is more weight than I feel like I can afford to give up. My little L has an LB400 loader, rated at 882 pounds of lift capacity. Do you know how much heavier your setup is than the standard Kubota bucket? My own bucket weighs 181 pounds.
Hmmmm ... Now that I look at it, my manual gives separate specs for the loader and the bucket. Does that mean the 882 lb loader capacity is already diminished by the weight of the bucket, so my maximum payload is already down to 701 pounds?
I might just be trying to rationalize why I can't get the 4-in-1, but I'd be interested in some hard numbers. /w3tcompact/icons/crazy.gif
   / W.R. Long 4in1 Photos #10
Bill,
Thats one heck of a nice setup you got there.
How much did the bucket etc.. cost,and did you install it.
Thomas..NH /w3tcompact/icons/wink.gif
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
