Verge mower versus offset frail
   / Verge mower versus offset frail #1
jcummins
Veteran Member
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
What is the difference? I'm thinking it an extra hydraulic cylinder to control the tilt downward....but can't find in reading the exact difference.
   / Verge mower versus offset frail #2
Hello and good afternoon jcummins,
Please visit the Iowa Farm Equipment web page so that you can see their line of Peruzzo flail mowers so that you can better understand how they work.
The offset flail mower is moved one or two positions to the right or left depending on the manufacturer to allow the flail mower to mower wider to the left or right depending on what the mounting frame position is and there is no hydraulic cylinder in use to shift the flail mower.
The side shifting flail mower has one cylinder and the boom mounted orchard and vineyard flail mower has two hydraulic cylinders.
The inner cylinder moves the outer boom in and out and the outer cylinder controls the tilt function which can drop to 45 degrees below horizontal and it can also be retracted to the vertical position to allow the operator to replace the hammer flails or mow along brush, orchard and weed tree lines to keep the weed trees back from the lane or to trim tall long hedges in two passes.
2008 FORD F-450 (A50854)
2008 FORD F-450...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
1986 Dorsey DFVPT-83 48 ft. Van Trailer (A50860)
1986 Dorsey...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
