Valve stem guards...
   / Valve stem guards... #1
Muhammad
Administrator
Moderator
San Diego, CA
None currently
Just sitting here wondering, has anybody mounted custom valve stem guards to their R1 or R3 tire rims? I know they come standard on most R4 tire rims, but can't remember seeing an R1 or R3 rim with valve stem guards. Has anyone made them, or found them? How much $/time? Of course, if the answer is no... I guess that means you guys aren't smashing valve stems very often, huh? /w3tcompact/icons/wink.gif
   / Valve stem guards... #2
I wish I had a valve stem guard recently when I "crushed" it accidently.
After all the calcium choride mix came out, have a new tube installed, refilled at about $120. later... (and I still mounted and dismounted the wheel myself)...
Yep... wish I had a valve stem guard then on that little Satoh R1....
   / Valve stem guards... #3
We have a ground department on campus,and all 4 Kubotas 3 John Deere have valve stem guards on each tire.
Our machine shop made custom guards out of 1/4" stainless steel pipe than welded the guards to the rims.
Thomas..NH /w3tcompact/icons/wink.gif
   / Valve stem guards... #4
I don't have them either on my R-1s. Wish I did here a while back when I had a wheel weight come loose and break the stem off.
JerryG
   / Valve stem guards... #5
I recall some messages over a year ago about welding valve stem guards onto the wheels; right after I ripped a valve stem out of a front wheel while pushing a pile of brush, but so far that's the only time I've ever damaged one.
Bird
   / Valve stem guards... #6
Jerry... Yiks! How the heck did you have a wheel loosen up/ come off?
   / Valve stem guards... #7
Muhammad,
My B21 came with front and rear valve stem guards (R4)/w3tcompact/icons/smile.gif
Oops, that original post should have read R3 not R4! /w3tcompact/icons/wink.gif Let me edit that......
   / Valve stem guards... #9
John,
It wasn't the wheel......It was the wheel weights on the wheel. The steel that was used for the weight bracket was tempered and when the weight attaching bolt was welded on, it caused cracks to form around it. That's what caused the weights to fall on the valve stem.
JerryG
   / Valve stem guards... #10
Muhammad,
I was going to say I must have got cheated on my R4's. I just popped one off two weeks ago on a bucket! They sure aren't very sturdy. My skidsteer has them on all tires and it sure is a good thing as every tire they are banged up pretty good. I was going to weld some on but didn't want to toast my new yellow rims!!! Only other idea I had was to put them on with bolts. Need to do something though.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Anvil (A50860)
Anvil (A50860)
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
Char-Griller BBQ PIT (A50860)
Char-Griller BBQ...
