Valve adjustments F3060 L3600
   / Valve adjustments F3060 L3600 #1
Rovcketman357
Shoemkersville,PA
F3060, L3600 GST
Curious who has done that. My owner's manual for my L3600 says to adjust every 800 hours [have not done at 1000 hours]. Wonder if needed? That engine runs cool.
My F3060 owner's manual does not mention valve adjustment- I have 2700 hours and have no idea if it was done before I bought it at around 2400 hours.
Both run just fine but can't hear lose valve clatter on a running diesel. And tight valves will only show up when you have a serious problem.
   / Valve adjustments F3060 L3600 #2
Tight valves are common on some engines. If the seat or valve wear even a small amount, the clearance tightens up. I would not wait until it runs poorly to check them.
   / Valve adjustments F3060 L3600 #3
You might post over on the Kubota Lawn section. There are a couple very knowledgeable people that frequent that section. I am sure you can get your question answered there.
Doug
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
8ft. S/A Utility Trailer (A48082)
8ft. S/A Utility...
8ft S/A Utility Trailer (A48082)
8ft S/A Utility...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
