Backhoe Value-Leader or WoodMaxx backhoe
   / Value-Leader or WoodMaxx backhoe #1
Kantukyboy
Wurtland ky
JD1020 MF1020
I would like to put a 3 PT backhoe on my JD1020. Have read all of the pros and cons on 3 pt and plan to build sub frame as needed. No one seems to make one for the 1020. Has anyone had any recent dealings with Value leader or WoodMaxx?
   / Value-Leader or WoodMaxx backhoe #2
Hello Kantukyboy,
Welcome to TBN. I bought the WoodMaxx WM-6600 last fall after a fair amount of research. And their price was very competitive. I've never used a backhoe before but I'm happy with it's operation so far on digging out a few small stumps and trenching for electric power to my pole barn. The only issue I had with it was an initial leaking at the PTO gearbox/hydraulic pump unit. But after talking to the service people at WoodMaxx they were quick to send out a replacement unit. My application is on a Kubota B7500 which is a small compact tractor. I did buy the heavy duty top link bracket and support frame kit that Kubota makes and recommends for use with their 3 point backhoe. I had time to change out the top link bracket but not install the support frame kit before winter set in here in Michigan. I was just careful to not stress my tractor. The support frame kit consists of 3 main pieces: a left and right side bracket that runs from the rear axle area to the front of the tractor and a cross member piece that connects the 2 side brackets underneath. One of the major problems with 3 point backhoes is the forces can twist and break the transmission (aluminum in many cases nowadays) and this kit minimizes that issue. Your JD1020 is a bigger tractor and you may not have this issue. Good luck with your search.
Thank you I am still looking and appreciate your thoughts.
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2005 Ford Five Hundred Sedan (A50860)
2005 Ford Five...
UNUSED Grey Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Grey...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
