using Glyphosate killing weeds before preparing soil; vegetable garden ??
   / using Glyphosate killing weeds before preparing soil; vegetable garden ?? #21
On health - the reports I say said "likely carcinogenic" but they are far from proving it. They just like to think it is 'cause it is effective. One of the reports indicated the surfactant was more dangerous that the Glyphosate.
Application - I've been reading that anything less than 41% is ineffective.
   / using Glyphosate killing weeds before preparing soil; vegetable garden ?? #22
You know, you don't actually have to kill a weed with a high dose to be effective. You can merely suppress it with a lower dose. I have done this for decades and it's a common agricultural practice. I use less than a 1% dose of the 41% concentrate and it works fine. It probably kills the weeds eventually but this is far lower than the label directions of 2% or more for hand held rates. I have actually used as low as 1/2% of the 41% concentrate and don't remember being disappointed.
Weed suppression, some hand weeding and people marvel at my garden. I never let a weed go to seed and the problem becomes progressively easier to deal with.
A couple notes here: if you use a lower rate and let the weeds that live go to seed you could build up a generational resistance to the herbicide. Don't do that. In the Midwest, certain weeds like Marestail ...
...have already become resistant to glyphosate and present agricultural problems because of this plus they produce huge numbers of seeds. I never let one go to seed, especially since 2,4-D is effective at killing it. And I don't spray them with glyphosate to prevent further resistance issues.
   / using Glyphosate killing weeds before preparing soil; vegetable garden ?? #23
Just a little bit of dish detergant has the same efect as the surfactant.
   / using Glyphosate killing weeds before preparing soil; vegetable garden ?? #24
41% is the concentrate, not what you'd actually apply. RoundUp is a slow kill, it takes 10 - 15 days for full kill and a few plants take a little longer. Mixing it stronger will show a more immediate burn down but, it doesn't actually kill the plant. I use a handheld sprayer for my RoundUp and mix it at 2oz 41% per gallon of water, which comes out to about 2oz per 1,000 sq/ft. That mix won't show any plant stress for almost a week but once the plants do start to curl at the leaves, they burn down quickly.
With most herbicides, a little patience is required to let the chemistry work if you want a complete kill. There are some that will burn a plant down in 24 - 48 hours but, they don't kill the root system so the plant will come right back in a week or two.
As was already mentioned, RoundUp metabolizes out as soon as it makes ground contact so it will do nothing to prevent regrowth. Since I'm intensely lazy, I like to use a pre-emergent in my beds once everything I want to grow has germinated. I have a license so I use Snapshot. Preen is also pretty good and can be bought at any home store, it just doesn't last as long. Depending on rain and humidity, I can get by with 2 applications of Snapshot a year. With Preen, you'd probably need 4 - 5.
If you decide you want to add plants to the garden after putting down the pre, you'll need to start them in post and transplant them once they're growing well.
   / using Glyphosate killing weeds before preparing soil; vegetable garden ?? #25
Sorry I should've clarified concentrate vs application rate. You are all correct.
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
Generator (A55973)
Generator (A55973)
White Metal Roof Panels (A55758)
White Metal Roof...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
