bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,070
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
After a heavy snowfall, when plowing becomes ineffective due to high snowbanks, I'll use my Woods RM74 snowthrower to clear portions of a mile long gravel and dirt road. As anyone who uses a snowthrower on a rough surface knows, picking up gravel and loose debris is a constant problem. In my case, it frequently shears pins and is the major cause of implement wear. In the past, I've set the height adjustment and top link length so the snowthrower rides a couple of inches above the "average" surface level. I then used the 3 point hitch to raise the implement when it started picking up debris. Doing this eliminates the float action by raising the implement off the ground. Snow then builds up under the unit, raising it further off the ground. This caused uneven results and required a second pass over the same ground. Frequent stops to adjust the height and top link length were required.
Quite by accident, I discovered a time saving solution to the problem. When setting up the snowthrower during the recent northeast blizzard, I couldn't find the proper length top link. Instead, I used the hydraulic top link cylinder from my T&T kit. By keeping my hand on the cylinder control valve, I was able to quickly adjust the angle and height of the cutting edge without lifting the unit off the ground or getting off the machine to make adjustments.
Many here may already know this but I thought I would share my experience. It's just another example of the versatility of a T&T kit.
