Upgrade seat in L or MX?
   / Upgrade seat in L or MX? #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
Anyone upgrade their seat in the L series or MX series tractor?
   / Upgrade seat in L or MX? #2
No replies? I’m sure some members have swapped seats...that’s probably my biggest fault with these tractors.
Mike
   / Upgrade seat in L or MX? #4
I considered replacing Grammar air ride seat in my Kubota due to wear.
Kubota price: $895.00 in 2020.
   / Upgrade seat in L or MX? #5
I bought a suspension seat for my B from Northern Tool. It wasn't air suspension but it helped a lot, as I recall it was $300-400. Took a bit of work to get the mounting modified, and the seat doesn't flip forward so it's not as convenient if I need to get under the seat to work on wiring or something. But overall it was a large improvement and worth the money. Northern also carries Grammer seats.
   / Upgrade seat in L or MX? #9
Jeff, when I was buying my L5460 a couple of years ago I asked the sales manager about the air ride upgrade from the standard suspension seat. He said the $895 upgrade was a swap of the base only. You might want to double check that.
   / Upgrade seat in L or MX? #10
I got the air ride with my new L4060hstc a few years ago. Can't compare it to the stock seat I never had, but I like it. As others have said the OEM air ride is a Granmar.
You do loose the ability to flip the seat up & run the PTO. I could do that on my old L3200. Now I have to put a couple rocks in the seat for it to not turn off when I get out spinning the PTO generator. I could bypass that sensor or put in a switch, but haven't had the time or motivation for as little as I use the PTO generator.
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
UNUSED PABREAK RGB240 - 84" ROCK GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
UNUSED PABREAK MPB232-72" HYD 4n1 BUCKET (A57193)
UNUSED PABREAK...
White Metal Roof Panels (A55758)
White Metal Roof...
