Uncut mowing circle for 2520 and 2305
   / Uncut mowing circle for 2520 and 2305 #11
JDFanatic...
because it's toooo hot /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif ... I will soon though...
   / Uncut mowing circle for 2520 and 2305 #12
JDFanatic...
   / Uncut mowing circle for 2520 and 2305 #13
Just as a point of reference, I have a JD 445 garden tractor with 54" deck.
I measured today, and in making a tight circle, the uncut inner circle was 6Feet in diameter, which suprised me. I thought it had a tight turning radius, but was suprised at how muct of an uncut circle it left..
Dan
   / Uncut mowing circle for 2520 and 2305 #14
Dan
I hear you, Dan. And, thanks for checking. When I test drove the 2305 with the 62mmm I was surprised to see it had a tighter uncut radius than my Simplicity Prestige!
Hope to go with the 2520 soon, but can't get my butt on one arround here to try.
Thanks for the info so far!
   / Uncut mowing circle for 2520 and 2305 #17
The 2520 with the 62D turning left has about an 83" uncut circle. If you turn right, it is about 94".
Hey TB,
First, thanks for measuring - I appreciate the feedback. /forums/images/graemlins/smile.gif
Second - Help me out here - I'm about to have heart failure! /forums/images/graemlins/shocked.gif
Hopefully, we are talking apples and oranges with our measurements. /forums/images/graemlins/smirk.gif
Please let me know how you made your measurments.
To clarify, what I mean by uncut circle is:
The smallest diameter patch of uncut grass remaining when you turn as sharp as possible through a full 360 degree turn.
As JDFanatic said for the 2210 (thus probably the 2305) it is around 3'. With the 2305 and the 2520 having turning radii within a couple inches of each other, I expected a smaller uncut circle. Did I miss something?? /forums/images/graemlins/confused.gif
Thanks for your comments!
Fud
   / Uncut mowing circle for 2520 and 2305 #19
Yes, the uncut circle is what I measured. I think it works out close. The 2305's turning radius is 7.4' and the 2520's is 8.2'. That is a radius difference of .8'. I believe that is about 9.6". Since this is a radius you times the 9.6" by 2 and add to the 36" and you get 55.2". I still stand by my measurement, but I wish the grass was taller so I could more easily see the edges of the circle.
   / Uncut mowing circle for 2520 and 2305 #20
tb,
Not to make this obnoxiously contentious, but, can you make a mark on the ground and proceed straight out from it, immediately turning the wheel sharp? After the tractor has returned to a position 180 degrees from the start, you should be able to establish the uncut circle. Somehow, I expect it has to be less than the country mile you describe. /forums/images/graemlins/confused.gif Please help enlighten us! /forums/images/graemlins/tongue.gif
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
