TYM T754 for Round Baling?
   / TYM T754 for Round Baling? #31
Ballasted I'm expecting the T754 to be around 8300lbs, maybe more with some cast wheel weights added. Do you think that is enough? I'm kinda thinking it would be marginal, but I don't have enough experience with that size of tractor to say with any certainty and I've never pulled a 5x4 baler to know just what that would feel like behind a tractor.
We use a old Ford 552 5x5 round baler behind our Kubota L3830, have had a lack of power, but traction hasn't been an issue.
Traction has been an issue running our NH 274 baler with a full kicker wagon in tow on the hill, but not with the round baler.
Haven't run the new MX6000 on a hill with the baler yet, but it is great on the flat field.
Aaron Z
   / TYM T754 for Round Baling? #32
Aaron Z
The round baler even with a full bale in the chamber is going to be a lot lighter than a small square baler, thrower, and a full throw wagon full of bales. I don't know how heavy a Ford 552 is but the 5x5 version of the baler I have would weigh about 6500-7000 pounds with a full bale in the chamber depending on what options the baler has. The small square baler, thrower, and throw wagon setup I use weighs about 11,000 pounds with the throw wagon full of bales. I will say that a pickup has a lot easier time pulling a round baler from field to field than it does pulling full throw wagons out of the field, the hay wagon is heavier and has zero tongue weight which isn't good for traction. The round baler has a lot of tongue weight pushing down on the rear axle which is good for traction. There is one hill the truck doesn't get enough traction to pull the hay wagon up unless it's in 4WD but it will walk right up that hill in 2WD with the baler.
   / TYM T754 for Round Baling? #33
Does anyone use a TYM T754 for round baling? I'm looking at picking up one for a lot of tasks, but the deal maker or breaker for me is probably round baling. I've currently got a Vermeer 604K 1000rpm baler, and TYM shows the T754 as having an optional 540/1000 pto on their website. I'm on hilly ground and I don't know if the T754 is enough tractor weight wise. If I get the tractor I would have it ballasted.
I don't really want a machine that needs DEF, and older larger pre-emissions tractors are holding a real premium on the used market. I could potentially sell the 604 baler and go to something like a 504, but I kinda want to have an idea of what I might be getting into before pulling the trigger. The T754 looks to me like a good value, if it delivers as advertised.
All opinions welcome.
I ran a JD 530 5x6 roller behind a JD 4230 with cab (weight), 100 PTO hp on gently sloping terrain. Coming up hills with a near full roll of sorghum-sudan hay it would start grunting...540 PTO.
   / TYM T754 for Round Baling? #34
I would never own a 5 foot wide bailer, simply because you cannot run 5 wide bales legally on the road on a trailer. 10 foot wide (side by side, exceeds the Federal maximum width of 104") Guy down the road has a 5 wide JD and got a ticket hauling them on his goose neck on a public road. State police cited him.
   / TYM T754 for Round Baling? #35
Fortunately, some states don't have those rules. Federal rules only apply to interstate use. That is less relevant out here in the west where the states are more than a couple of hours wide. In Texas, you can haul up to 12' wide loads of hay (with $10 annual permit). South Dakota has no width limit for farm machinery driven by a farmer during daylight hours (except on Interstate Highways). Nevada allows up to 120" on roads (other than Interstates). Even Michigan allows up to 108" (though that does not help much). Also, the federal limit is 102", not 104".
   / TYM T754 for Round Baling? #36
Actually, it's 104 for curtain side flat bed trailers where the curtain is mounted to the outside of the rub rails on a 102 wide trailer. I know as I dealt with just that before I retired from trucking.... and, there is no limit of width (here in Michigan at least) when pulling farm related implements on public highways except they have to have flashing amber warning lights and display a triangle SMV placard facing rearward and allow safe passage of motor vehicles, in other words, pull off the road and show courtesy to them.
I routinely pull implements much wider than 10 feet on public roads all the time. The one place you cannot is on a limited access highway unless that is the ONLY route to your off farm fields and then you have to have a permit issued by the Michigan State Police and display it.
I believe both Ohio and Indiana are the same. Not sure about other states as they don't impact my operation at all.
The 102 rule applies here when transporting ag related commodities (round or large square bales) on public highways, whether they are paved or gravel.
   / TYM T754 for Round Baling? #37
Sounds like a lobbying opportunity by the State Ag Co-ops and such.
I love how complicated they make a relatively simple issue. Smh
   / TYM T754 for Round Baling? #38
It's not very heavy, 2000-3000# (ish), plus the bale in the chamber (3000-4000# total?), our 1/2 ton Suburban had no issues towing it home 40ish miles.
Not enclosed, can see everything it's doing, string tie, not netwrap.
As I understand it, it's a Gehl RB1500A with blue paint.
If we had to haul them, I would agree, but we bale them and use them on the same farm, for the price we paid and for the 30-60 bales per year we make with it, it works well.
Aaron Z
   / TYM T754 for Round Baling? #39
Never been cited, even in roadside inspection for being 10’ wide with ag crops. Also, 5’ bales could be hauled in a single line, not double rows.
   / TYM T754 for Round Baling? #40
We can go 12’ with crops.
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2017 Ford Expedition SUV (A56859)
2017 Ford...
JOHN DEERE 1560 - 15' NO TILL GRAIN DRILL (A52708)
JOHN DEERE 1560 -...
