Gregster613
Platinum Member
- Joined
- Apr 19, 2009
- Messages
- 694
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi All, 1st off Happy New Year to all TBN'rs.
I had either a switch or relay go bad in my hazard warning light circuit. I never travel on the road anyhow so it didn't affect me other than the fact that some day - I might need to do so, and I don't like having something on my tractor that doesn't work.
So I gathered up part numbers from my antiquated parts manual, called Ken at Jordan's Tractor to find out if I could even get anything. Well he had the relay and switch on hand so I bought them (at a very reasonable price even). The parts swiftly came and I set them on the shelf because I was in no rush to tear apart my dash to replace them. Months go by - finally we had some lengthy rain days so I got to it.
I replaced the relay first as I hoped that was simply it. No luck there. Then I get the switch out and lo-n-behold the replacement switch won't fit my harness! It's an updated, superseded switch that won't do me any good. Hazard switch, K2 #13157072501 is the replacement. What's up with this I think. So I texted Ken with all the old numbers that I now had in front of me from my old switch and asked him to see if he could find me one. Ken called TYM with my part # info and they had a replacement harness assembly - #11616683000 which is nothing more than a short strand of wires with the required plugs needed on each end. They drop shipped it directly to me at home and at NO Charge!!
I plugged it in last night and wow all lights work as they used to and everything is good again!!
I wanted to shout-out my Kudos' to both Ken at Jordan's Tractor and to the main factory of TYM. Great service and swiftly rendered! These days it seems as if that's sort of a hard thing to come across and since I did I wanted to give my Thanks to all in the universe. TYM'rs if you need parts be sure to give Jordan's a call. If it can be gotten, Ken will get it for you.
Lengthy post I know but I'm extremely happy and satisfied! Happy New Year to all - Greg
