turning Plow / middle buster
   / turning Plow / middle buster #1
Fisherman305
Monroe County WestVirginia
I have a single turning plow that i am considering replacing the bottom and then install a middle buster. What I am trying to say is use the plow by changing the bottom from turning to middle buster and then back to turning as the need arises. Has any one ever attempted this?
   / turning Plow / middle buster #2
I do that with my subsoiler, unbolting a moldboard plow must be a lesson in frustration. With my subsoiler two bolts removes the tooth, and two bolts attach the shovel.
   / turning Plow / middle buster #3
Well, a number of companies make such devices. I have a middle buster / subsoiler combination from Howse. Two bolts hold the appropriate blade, and you can set the depth of work with some combination of the 3ph height and an adjustable shaft (like most rippers on box blades) for the plow attachment. Works just fine.
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2016 Ford Fusion SE Sedan (A55853)
2016 Ford Fusion...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2017 Ford F550 Crew Cab Service Truck (A56858)
2017 Ford F550...
