Tires Turf vs. R4 Tires
   / Turf vs. R4 Tires #31
I moved from turfs to R4's on my B2920. We've had a lot of rain here in Maryland (and some snow) and moving my tractor in and out of my pole barn and across the wet yard has really tore up my lawn in front of my pole barn. I don't think the turf tires would have done near the damage as my R4's.
If the lawn had been dry, it probably would not have made much of a difference. In the snow, both R4's and turfs seemed to offer about the same amount of traction.
   / Turf vs. R4 Tires #32
But your post wants to end the conversation with the obvious, when in practice its not that simple. One might be less of a compromise to do the other duty than the other tire is, & I'm interested in hearing more experiences from people that have actually used both in similar situations.;)
And snow is another dimension that isn't covered by any of the generalizations, but sometimes is just as important to the decision.
Yes, apologies. I am running R4s on lots of loose dirt and lots of slope. I do go across grass on a slope and when its wet, the R4s tear it up. My previous experience with turfs is they don't give enough traction unless on fairly level ground. I haven't had snow experience with either.
   / Turf vs. R4 Tires #33
I use titans griz turf tires, they are great much better than R4's, I had on 2320, just a good all around tire, I don't use it in heavy mud, we had a lot snow last year n didn't need chains, R4 would spin on 3-4" of snow n tear up lawn a lot easier, I'm very happy with these titans griz turf n they look cool on my tractor ��
   / Turf vs. R4 Tires #34
I've had both turf and R4 tires. Turf grip much better for turning and therefore tear up grass because they grip. R4s slide sideways.
If I had my choice, I'd go with turfs.
Ralph
   / Turf vs. R4 Tires #35
My BX2670 came with R-4's because "that's what they had in stock because everyone wants them" and I've hated them from day one to the present. If I had a loader and played in the dirt, I might choose differently. If fact, yes I would, I'd want agricultural lug tires!
While this is my first Kubota, I've ran various types of lug and turf tires to mow grass and do garden work for 45 years. In that time I've found ag tires work best for mowing the yard, working the garden, and general playing in the summer. The ag tires spun less than turfs, thus tore up the lawn less. In winter, swap on some turfs with chains. Rubber spins on ice if you have a real winter where the ground freezes, no matter what the tread pattern. Chains disappear between the lugs of ag tires and become virtually useless. The R-4's aren't quite as bad, but they still swallow chains to a degree which lessen their effectiveness. Not to mention they are rough riding where the chain does cross a lug.
Speaking of rough riding, good grief, those R-4's are beating me to death. Either turf or ags would give a much smoother ride because they aren't as stiff. I'm down to 5psi in the rear tires hoping for some flex, and still waiting for that flex.
Sure wish I had waited for turfs, even though the snow was piling up and I had no way to clear it. Since this is my first 4 wheel drive tractor, the lesser traction of the turfs could easily be offset by engaging the front wheels when needed.
Of course, others needs and desires will be different, but in my case, where most of time I'm mowing the yard, or pulling a subsoiler/ground breaker, dragging old fences out of the brush, and blowing snow in winter where there is frost in the ground, turfs would be the best, overall, never change, tread type. In a perfect world, I'd have ags all around in summer, and swap on different rear wheels with turfs and chains permanently mounted on them. I can swap rear wheels faster than I can install chains.
One thing haven't tried, is studs in the front tires for winter. I think R-4's would be excellent for this. Coupled with chains on turfs on the back......
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2004 CHEVROLET C5500 PASSENGER BUS (A51243)
2004 CHEVROLET...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
2020 Toro 6000 Series 60in Zero Turn Mower (A50322)
2020 Toro 6000...
