Turbo
   / Turbo #11
That sounds more like "turbo normalized". IE, the higher you get from sea level, the less dense the air. Horsepower is a factor of how much air/fuel you can get into the cylinders. At elevation, you get less air in the air so you need to also reduce the ammount of fuel to get a proper combustion ratio. This all adds up to less power available at altitude. Turbo normalization makes the engine think it is at sea level when it is at 7-10K feet and crams the same ammount of air in as a sea level engine would get. It is not a 30% HP gain, it is just not a 30% horsepower loss that the non-turbo engine would experience at high altitude. It also dosn't put any appreciable additional wear/tear on the engine that a system that boosts the pressure significantly above atmospheric pressure does.
A properly setup turbo has virtually no "lag" and power is fairly linear to RPM when under load. The beauty of the turbo is that it is more dependent on load so when you are not loading the engine, the turbo is just ideling along. It is also using waste heat(exhaust) from the engine where a belt or gear driven supercharger blower has a power demand from the engine even when you are not needing the power gains that it can provide.
   / Turbo #12
<It doesn't seem to make any big differences here at the store in Ft. Worth, but at higher elevations, it really made a big difference in the hill climbing ability of the RTV.>
I believe this turbo is to maintain air pressure at sea level pressure. This would then not gain any hp at low elevations.
I'm interested in boosting hp at low elevations. Anyone know anything that's available?
   / Turbo #13
yes it's called nos!!! get a bottle of that and hook it up when you feel you need a ltttle more power just open the valve.lol. oh i forgot rtv is diesel. has anyone thought of trying banks deisel productsthey might have something that might give the engine some pep.wait they do make nos kits dor deisel
http://www.usdieselparts.com/hi_perf.cfm
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
Industrias America F07 (A56469)
Industrias America...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
Ford 4630 (A53317)
Ford 4630 (A53317)
1997 Caterpillar D3C Series III LGP Crawler Tractor Dozer (A55851)
1997 Caterpillar...
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
