Turbo RTV1100
   / Turbo RTV1100 #31
In Star Wars episode one they had those wonderful motors on their pod racers. Maybe you can fancy one of them up to help take the pressure off the new turbo:D
Good luck on the rockets, make sure you post pictures of the install:)
   / Turbo RTV1100 #32
What kind of "paint" did you use that can stand up to those kinds of temps?
   / Turbo RTV1100
High Heat flat black paint for exhaust components. Kubota gray for air inlet/outlet tubes.
   / Turbo RTV1100 #35
Again i say nice work. Now the only thing you need is a "turbo" sticker on the side.
Shane
   / Turbo RTV1100 #37
Where can I but a turbo kit for my 900 somewhere near the east coast.
   / Turbo RTV1100 #38
MikeyD,
Given you are probably only running a few psi, it's probably no big deal cooling or not. Just has more "pizzaz" to be able to brag about your intercooled turbo Kubota. Not that you need to top having a turbo in the first place, especially when you can always let it drop "oh yeah, I designed and built it myself from some spare parts that were lying around....".
   / Turbo RTV1100 #39
Didn't know there was such a thing. All I knew about was ceramic coating. How much heat can this paint see?
   / Turbo RTV1100
Below are a couple pics of the pyrometer install. First one is the bung welded in the exhaust pipe before the turbo, second one is the gauge mounted in the cab. I didn't want to cut the dash so I made my own bezel out of sheetmetal and painted it and the back of the pyrometer Kubota gray. The pyrometer measures Exhaust Gas Tempature (EGT). In a turbo diesel you don't want to exceed 1100 to 1200 degree's or you can melt the engine. Under light load it barely registered over 250 degree's ( the lowest the gauge goes) Under medium load it rose up around 500 degree's. I took it out to the field in in about 2 feet of wet heavy snow and ran the heck out of it in real tight turns wheels spinning for about 10 minutes straight to simulate heavy load, it ran up to 875 degree's and stayed there. All tests were done in 4wd to create drag.
So everything is well w/i spec. I am going to leave the pump alone, it's running strong and I don't want unburnt fuel raising the EGT. It is interesting how the EGT goes up and down under load and off load. I am glad I got the pyrometer for the peace of mind.:) :)
2014 Dodge Charger Passenger Car (A55853)
2014 Dodge Charger...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A57193)
UNUSED IRANCH...
40006 (A55788)
40006 (A55788)
2025 Heavy Duty Wheel Balancer Machine (A55852)
2025 Heavy Duty...
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
UNUSED FUTURE FT-GR87 87" HYD GRADER (A57193)
UNUSED FUTURE...
