True operating weight
   / True operating weight #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Can anyone shed a little light on wheather Kubotas listed weights are dry weight or with all the fluids.
For example, my 7500hst is listed at 1367lbs. With me, it goes to almost 1700lbs (not counting any implements). How much weight do all the fluids add to a typical tractor?
   / True operating weight #2
Kubota weights are without wheels and tires and minus fluids I think. J
   / True operating weight #3
A gallon of diesel is around 5.2 lbs, a gallon of oil is about 6lbs, and hydro fluid is about 6lbs per gallon. so the answer to the question - <font color=blue>How much weight do all the fluids add to a typical tractor?</font color=blue> is - Not much.
   / True operating weight #4
Are you sure about the 5.5 lbs for diesel? I thought it was more like 8.8 lbs.
Don
   / True operating weight #5
water is 8.33 pounds/gallon and oils float on water so I would asume that they weigh less. hydro/tranny fluid is about 7.2 a gallon.
   / True operating weight #6
My mistake. I picked that number up in another thread. :(
Don
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2016 Kubota SVL75-2 (A50123)
2016 Kubota...
2007 Yamaha Rhino 660 (A53473)
2007 Yamaha Rhino...
