Troy-bilt tiller seal replacement
   / Troy-bilt tiller seal replacement #1
garry
Bronze Member
Ohio
JD 1050
I have an old Troy-bilt tiller that leaks oil around the axel seals. does anyone know how these seals are replaced?
do I have to split the transmission housing and drive them out from the inside? Do I need special tools?
   / Troy-bilt tiller seal replacement #2
I've been meaning to reply to this. I keep forgetting to look-up the replacement procedure when I get home. I replaced the seals yrs. ago & I don't remember what all I had to do. I have the manual at home.
   / Troy-bilt tiller seal replacement #3
What axel is leaking? The one that drives the tires or the rear axel for the tines. I have a service manual and can check. I did both mine a few years ago but can't remember the exact procedure for each.
Dave...
   / Troy-bilt tiller seal replacement #4
I had to change my drive axle seals about 20 years ago. The biggest problem was getting the wheel hubs off. You have to drive out a roll pin in the hub, no problem and then pull the hub off of the axle, big problem. I wound up welding a LARGE nut on the hub so that I could screw in a large bolt against the end of the axle and push the hub off of the axle. I just kept the bolt in my toolbox for future use.
To the best of my memory the seals can be changed from the outside of the tranny case.
Just changed the seals on the wheel axels and it turned out to be a piece of cake. wheels came off easy and seals came out with a screw driver.
   / Troy-bilt tiller seal replacement #6
You are SO lucky. Glad it worked out fine.
2003 John Deere 1600 Turbo Ride On Mower (A50860)
2003 John Deere...
19011 (A48082)
19011 (A48082)
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
