Trickle battery charger
   / Trickle battery charger #91
Thanks for posting this. Just put one on my Christmas list!
you might want to look at the noco i posted, it is more compatible with more batteries and is only 3 dollars more
   / Trickle battery charger #92
Ok? for 3 dollars more you get the agm and lithium profile. seems like a no brainer to me
As mentioned earlier, AGM batteries seem to do just fine with the BatteryMINDer's output. If really wanting AGM specific voltages instead, it's easy enough to adjust the output.
And it's not about the money. Basically, I know they work, trust them, and have lots of them. What I don't have is a lithium battery, or an actual need for an AGM setting on a maintainer.
Anyway, it looks like NAPA has a Noco-like version for $18 if money is tight.
   / Trickle battery charger #93
The Noco just dropped again, must have read this thread now is only 20 dollars.
   / Trickle battery charger #94
Alright, ordered one just for kicks.
It'll be interesting to see if it can indeed revive dead batteries.
   / Trickle battery charger #95
I am not sure if it has the manual repair mode the larger models have FYI. I would check that
   / Trickle battery charger #96
It said it does. But descriptions on Amazon has been wrong before.
At least the low amperage is good for nursing wounded batteries back to life.
   / Trickle battery charger #97
the manual does not indicate a manual repair mode, just a force mode for batteries that are too low to be detected. Just an FYI. I have a 10A model that does manual repair. but my understanding every charge cycle on the noco, does the desulf at the beginning of the charge.
   / Trickle battery charger #99
Have four of them.
Work fine.
Would not charge a totally discharged deep cycle battery until some juice was in it.
Good Luck!
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
