Trade tricks/Hacks to get grease points to work properly.
   / Trade tricks/Hacks to get grease points to work properly. #1
super55
Platinum Member
Great North of Michigan
Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
Several grease points on my FEL on my tractors have some pretty stubborn grease points. They will take grease but a lot of times only lubricate one side of the bushings. Anyone have any tricks to get them to work properly again?
Sometimes I get the old grease to break free but heating it with a torch for a bit but even that a lot of times only has marginal results.
   / Trade tricks/Hacks to get grease points to work properly. #2
You could acquire & use a grease zerk cleaning tool.
   / Trade tricks/Hacks to get grease points to work properly. #4
Make sure the tension is of the pins when greasing... If you have a second person, have them move the pin joints via the FEL controls very slowly while you grease the fittings.
Worse case you may have disassemble the pins & clean them up really good & then reassemble...
   / Trade tricks/Hacks to get grease points to work properly. #5
I see that on my tractor, on mine it’s not clogged and after I use it a while grease comes out the other side eventually.
   / Trade tricks/Hacks to get grease points to work properly. #6
I have seen this a few times on various equipment. I have taken them off and cleaned them.
Good ideas here so far, I'll be watching to see what I can take away too. Gonna get a zerk cleaning tool...
   / Trade tricks/Hacks to get grease points to work properly. #7
Sometimes it helps to position the thing whose pivot you're lubing in a different position. So the load is on a different side of the bushing.
The zerk cleaning tool looks useful, but it fixes a different problem than grease not getting to one side of the bushing.
Thanks for all the suggestions. I'm definitely going to get one of those cleaning tools.
Any particular fluid that works best for breaking down 20 year old grease. Thinking something like acetone or lacquer thinner might work good at weakening rock hard grease.
   / Trade tricks/Hacks to get grease points to work properly. #9
Just fill grease fitting cleaning tool with some lightweight oil, then place it on fitting and hammer home! It's the pressure that loosens everything up.
   / Trade tricks/Hacks to get grease points to work properly. #10
I never had a zerk that wouldn't take grease. As mentioned, you could try shooting the grease in with weight on / off the arms, etc.
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
