Oct 23, 2014 / Tractor stops when clutch depressed ... doesn't coast ... #11 Tx Jim New Member Joined Jan 26, 2007 Messages 10,335 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC I would venture to guess that some brake springs & sensors have failed while tractors were under warranty.
Oct 23, 2014 / Tractor stops when clutch depressed ... doesn't coast ... Thread Starter #12 OP D DPForumDog Member Joined Mar 28, 2013 Messages 32 Location bham Tractor not yet dieselbeef said: yep..txjim nailed it..get busy with about 500 in parts..unless ya break the disc Click to expand... Diesel beef, what makes up the$500. I thought it was (3) $26 springs? Thanks
Oct 27, 2014 / Tractor stops when clutch depressed ... doesn't coast ... #13 D dieselbeef Gold Member Joined May 6, 2010 Messages 273 Location myakka city Tractor bx2200..jd 2010 loader backhoe tractor well ya got the springs and I did the fiber discs and of course I broke one of the discs prying it out you do realize your doing both sides..left and right axles right? the oil isn't cheap either...and theres a lot of it gary
Oct 27, 2014 / Tractor stops when clutch depressed ... doesn't coast ... Thread Starter #14 OP D DPForumDog Member Joined Mar 28, 2013 Messages 32 Location bham Tractor not yet Yes, it all add up. And I was told we need to add replacing ORings to that list $$$$$$$$$$$
Oct 30, 2014 / Tractor stops when clutch depressed ... doesn't coast ... #15 D dieselbeef Gold Member Joined May 6, 2010 Messages 273 Location myakka city Tractor bx2200..jd 2010 loader backhoe tractor yep..do em while yer in ther..if they leak by the pedal will fade
