Tractor stability going uphill vs. down
   / Tractor stability going uphill vs. down #41
I've found since buying my 1st tractor in 2015 that I have learned to think of a tractor more like my motorcycle history than my car/truck history when it comes to slopes/hills/side hills. Why? Well with cars and trucks you think of "wheelbase" as a key ingredient to stability. But with Motorcycles and sub compact tractors its much more about "footprint".
On a flat - both a motorcycle and a sub compact tractor offer good control at speed and at slow. But on hills, angles, and curves - slow speed becomes tricky for both of them especially going slow. A sub compact tractor "seems" like a square or rectangle as far as foot print - but the reality is its a triangle because the front axle footprint pattern changes as you steer it. Both front wheels when turned, reduce the outer footprint to a smaller size creating a natural lean potential. When backing down a hill - the rear wheels never change their footprint width - so greater stability exists when in combination with weight balances front and back. In other words backing down a hill has less "leaning potential".
Now this was always an issue on a motorcycle trying to turn around when going slow - its hard to keep the bike from wanting to stay upright. But I never considered this a possibility on a tractor - as the tendency is less on lawn mowers - and I would not naturally desire to back down my steeper hills with my fel on - but I learned.
The whole concept of the front axle being a pivot on a modern sub compact or compact tractor - is not obvious by appearance - but its certainly quite "seat obvious" - especially because the operator doesn't get a lot of "lean" control like you do on lawn mowers or atvs. Looking at tractors of the past with two front tires right next to each other - its no wonder farming was such a very dangerous activity when your land had hills and slopes to be plowed and planted.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
(2) Bridgestone Tires & Rims (A56469)
(2) Bridgestone...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
