Omnipotent
Bronze Member
- Joined
- Sep 22, 2010
- Messages
- 69
Posted in Bobcat thread, but this is a generic engine question so placing here for more feedback.
Long story short, we just went into a deep freeze and a snow storm, so the tractor was needed. Went to move the tractor into "position" by the driveway the day before, tractor was hard to start but I just attributed to cold and been several weeks since it was last run, started, drove and turned off. Next morning, again really hard to start, so hard that I needed a battery jumper to get it going...after 2-3 minutes of work, tractor started and off I went to clear driveway. About half way through I notice antifreeze smell, by the time I noticed it I had been using it for ~20 minutes (thought is was steam from snow until I got a whiff) and then another ~5 minutes turned tractor off and parked it.
Now the fun begins, next day went out to use it again (wind blown drifts upwards of 2 feet over night)...tractor wouldn't start. Got out the battery tender again, threw it on 200 Amp and could get it to start for 5 seconds or so, but then it would die. Over and over again. Gave up and got out the snow blower.
Fast forward a couple more days and today was a warmer day (40 degrees) and decided to go take a look at tractor. Same, same. Throw on battery tender and crank away...got it to run for the longest of <20 seconds. Can't place any load on it or dies immediately. Trying to crank up RPM's dies as well.
Checked oil, plenty there. Checked anti freeze, low to empty, added anti freeze (during all the cranking and short stints of running, could not see any leak from radiator or hoses). What I did notice is oil burning through the exhaust pipe (the section where to two pipes join, oil bubbling out and burning). For the record, it seems like when it runs it's running much rougher, although I could be off on that, but seems like a loud knocking that may or may not have been there all along (you know when things are wrong you start hearing everything).
My gut is telling me I blew a head gasket and because of the lack of compression that is why the engine keeps dying after 10-20 seconds...thoughts? Other ideas?
