Tractor backhoe - homemade
   / Tractor backhoe - homemade #1,181
Making photos is not allowed in the factory.
And we work quite differently with pre-bent steel, using welding clamps to let them follow contour, will not work with the 12mm upwards sheet thicknesses we work with, thats why im very interested in the solutions Bfreaky comes up with 😉👍👍👍
Talking about bending solutions...10 tone bottle jack did it...;)
   / Tractor backhoe - homemade #1,183
I'm wondering why not use an oxy/acetylene torch to heat the metal in the area of the bend & then bend it? There is probably some advantage in stress reduction & weld penetration as well.
rScotty
Ou that's simple...because I don't have a torch :)
   / Tractor backhoe - homemade #1,185
Stick some double folded heavy grit sandpaper under the jack for a bit of traction.
It did not slide because it's hooked at the right spot. Plate went down without problems. There are no new pictures because last few days I'm only heavy welding those booms
   / Tractor backhoe - homemade #1,187
I was the only one wondering why the strap didn't break while jacking, guess I'm the only one that Murphy helps.
I've put a round thick metal plate on top of the cylinder so it could not pierce the strap
Heavy welding boom no 2.
   / Tractor backhoe - homemade #1,190
This heavy flat welding would be a good place for 5/32 7024.
2015 MACK CXU TRI-AXLE DUMP TRUCK (A58018)
2015 MACK CXU...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
HAULING S/A TRAILER (A52708)
HAULING S/A...
2006 FORD F-150 PICKUP (A58017)
2006 FORD F-150...
