Torque wrenches
   / Torque wrenches #41
My Kobalt was made in the USA, J H Williams was the manufacture in Columbus, Georgia. I bought it in 2001
   / Torque wrenches #43
But, you need to subtract 30% from the clean dry torque value to prevent fatigue or outright snapping the bolt off. If you don't believe me, just google wet torque vs dry torque. Also, read the article I linked above.
The generally acceptable guidance is only lube if specified in the technical manual.
Overtightened bolts will not cause fatigue.fatigue is caused by repeat loading of the bolt. You can snap a bolt by overtightening.
   / Torque wrenches #44
I have a Warren and Brown beam type 3/8 torque wrench. Gives visual and audible indication. Used it for years on VW engine work. Just have to remember to reset the clicker every time. Also have a 1/4 drive in/lb beam type for auto trans work and a cheapo ratchet 1/2 for domestic engines and such. Oh so glad I don't have to do that stuff anymore.
   / Torque wrenches
In continuing my research I read something interesting about the Harbor Freight ICON brand torque wrench yes it has a lifetime warranty but the warranty is only valid if you have the wrench calibrated every 90 days .... right out of the owners manual . That one is off y list
   / Torque wrenches #46
I purchased a Tekton torque wrench very happy with it.
   / Torque wrenches #47
Exactly the same as the Pittsburg (HF) wrench, right down to the plastic case. Lots less at HF. Problem with cheap wrenches is, they only indicate in one direction.... right. Not left.
I own the Tekton trust me NOT the same as harbor freight ..I shopped both before I bought.
   / Torque wrenches #48
Check out Tekton. It’s a family owned business from Michigan that imports 75% of their tools from Taiwan, 20% are made in USA, and 3% from China.
I did a lot of research and found that Tekton tools hits the sweet spot between price and quality. And all their tools have a lifetime warranty.
I have their 1/2in torque wrench which I really like.
My current favorite tool is Tekton’s 18in 3/8in non-quick release ratchet. It provides great reach and leverage and its slim design fits well into tight spaces.
About Us | TEKTON(R) Tools
   / Torque wrenches #49
I’m sure that everyone knows to twist the torque setting (post beam and pre-electronic) back close to zero before storing ., You should not set the torque to 150 for example and just put the tool away, crank it down before storage.
   / Torque wrenches #50
Tekton blows hf out of the water, its like comparing snapon to craftsman.:drink:
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56435)
2019 BOBCAT T630...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A58017)
2007 INTERNATIONAL...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
