Top n tilt and quantity of remotes
   / Top n tilt and quantity of remotes #1
Theof
JD 1025TLB
Would like to add fit rite top n tilt to L6060. Currently have two sets of remotes. It appears TnT requires 2 sets of remotes, so will I have to add 2 additional sets of remotes to use my snowblower which requires 2 sets also. Don’t think my tractor can be set up that way.
   / Top n tilt and quantity of remotes #2
The L60 series is limited to (3) sets of OEM remotes, but there are several aftermarket options to get the (4) remotes you want.
Summit hydraulics is a popular supplier.
I have (2) sets of OEM remotes on my L4060, and am in "Analysis Paralysis" over biting the bullet on adding (1) additional OEM remote, or using one of the various splitters available.
   / Top n tilt and quantity of remotes #3
For the appplication, cheapest route available. How often will you really need to adjust all 4 instantaneously? Also, IME, it is very difficult to move 2,3,4 separate levers at the same time and rate.
   / Top n tilt and quantity of remotes #4
In order to add a 4th remote on my L6060, I added a 4th OEM breakaway coupler housing to the stack.
I then ran hyd. hoses forward and connected them to the 3rd function valve:
A diverter would have been cheaper, but I already had the 3rd function valve installed. I only have a couple of implements that require 4 remotes. I don't use them often, so I didn't bother routing the hoses under the tractor for a more permanent install. I might do later if necessary.
   / Top n tilt and quantity of remotes #5
The easiest way to get the additional sets of rear remotes is to add a diverters. With the diverters you can have (in your case) 3 sets of controls all with one control lever. :cool:(y)(y)
Simply add a control grip (probably to your #2 control lever) to one of your control levers and you then have the capability of controlling 3 separate functions and never move your hand from the control lever.
I now have poppet-type diverters, so no more drifting (y) with the internal leakage that Kubota is known to have with their rear remotes. It sounds like you need a triple diverter to gain your 2 additional sets of couplers. I only have a picture of the 4 diverter set. So you would need a triple diverter set with the control grip as seen in the separate pictured control grip for your application.
Contact me if you are interested.
   / Top n tilt and quantity of remotes #6
If you can you are either a rotor wing pilot, or a grader operator.
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
PumpJack Brand Pump Jack (A56436)
PumpJack Brand...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2323 (A58376)
2323 (A58376)
