tooth bar mounting spacing
   / tooth bar mounting spacing #1
big bubba
Elite Member
arkansas
M8540
Members: Purchased a Woods tooth bar for the 72' bucket on my 7040. Looks as if I'll have a welder shorten the length to fit inside my bucket (not custom made as others) I was thinking of having a few washers placed between the bar mount and bucket so debris could be removed to prevent rust etc. Or would you have it flush mounted? Your thoughts? just want to do it right (realize there should be some clearance anyway) thanks bb
   / tooth bar mounting spacing #2
big bubba
Mine is an atc brand and fits in tight that way if you hit a tooth dise ways it dosent rack the whole assy.
the only thing I would do different bar has a slotted 1/2" hole for bolts and i drilled tward back of slot. If I would have drilled to front then I could just loosen bolts and flip over to use the straight blade
tommu56
   / tooth bar mounting spacing #3
I like between an eighth and quarter inch clearance on both ends. Makes it easier to install and remove.
Once you add a couple thick washers, the tooth bar will be quite tight.
As Tommu56 wrote, if your mounting holes are slotted rather then just a round hole, drill and mount nearest the front of the slot so you can loosen, pivot up and tighten when you need to back drag.
I didn't...drilled my mounting holes aft and cannot pivot the bar. That was a mistake.
   / tooth bar mounting spacing #4
can anyone post pictures of this? I'm not sure I quite understand - probably because I'm new to this stuff.
I will be doing this soon, and want to get it right...
Thanks.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
