To Screw, or Not To Screw....
   / To Screw, or Not To Screw.... #1
3930dave
Super Member
Canada
Ford 3930
That is the question....
I came across all of these just recently, with screw in Oil Fill caps that are also dipsticks.
One was an old Honda semi-automatic (believe it or not) car transmission, another was my new Briggs generator engine, and also a small Honda aircooled engine about 7 years old.
I've seen the manuals for 2 out of the above 3.
Both manuals state that to check the oil level you unscrew the disptick, wipe it off, and insert it back into the fill hole, without screwing it in. IE. don't engage the threads at all.
My initial instinct was to screw the fill plug all the way in, then unscrew it to read the level. Same reaction from a few people that I know, who are all pretty mechanically/maintenance aware.
I'm not questioning the manufacturer's instructions, I have no problem with what Honda or Briggs is telling me - when I know the right info that is !
So.....
1) Is this the standard practice across the industry for Oil Fill-Screw-in-Dipsticks ? (Don't screw it in, to check the Level).
2) Has anybody come across an exception to this, where you do have to screw the cap all the way in to properly check the fill level ?
The difference in level amounts to easily 1/2"; I consider this non-trivial esp. in a small sump.
Rgds, D.
   / To Screw, or Not To Screw.... #2
So.....
Rgds, D.
The Kohler Command on my JD lawn tractor is a no-screw check, while the Techumsa on my DR lawn n leaf vacuum is a screw-in to check. Guess you really have to read the manual
Read The (Fine) Manual ?
Whoa ! Patches....... easy on the crazy talk here ! :eek: :laughing:
Thanks for the Tecumseh example. They are out of production at the moment, but there are lots of those engines around, and hopefully will get put back into production.
I posted this 1) to find out trends/exceptions, and 2) I could see plenty of people getting into trouble (either way) with this level measurement.
Of the 3 items mentioned, the one I own is the Briggs Gen. It is getting labelled about this check. It does have Low Oil Shutdown, and there are very few people it would get loaned to, but I'll sleep better with an UNscrewed label on it.
:soapbox: I was hoping that the engine industry had settled on ONE way of doing this, being the dreamer that I am :rolleyes:
Rgds, D.
   / To Screw, or Not To Screw.... #4
Not only is there no standard method. Kohler has some engines that you screw in and some that you don't.
   / To Screw, or Not To Screw.... #5
Ya that, and the Honda generator has no dip-stick at all; something like fill to the third thread from the bottom of the fill port, LOL
I'm reminded of the software developers favourite line " No, it's not a bug, it is a feature ! ".
Head of Kohler Marketing sits down with head of Kohler Engineering:
"We need you to make these oil dipsticks LESS intuitive".
"Say what?".
Let's see.... 90% of consumers pay little (more like no) attention to maintenance. Of the 10% that do, there is maybe what, 10% of those that actually read the manual. So out of 100 guys/gals, you get perhaps one that is clued in.
I can understand the Marketing angle here.
From an Industrial Engineering standpoint though, this is nonsense.
Patches - that Honda approach is a bit goofy too. But, at least it is not ambiguous, once you know the Secret Water Buffalo Handshake that is.
Some of these Marketing clowns likely drifted over from the Auto sector - lots of examples there where the factory doesn't want you checking fluids.
:thumbsdown:
Rgds, D.
   / To Screw, or Not To Screw.... #7
My Coleman gennerator is the exception, you screw it in to check it. I didn't and after running for 30 minutes or so the oil mush have finally foamed up enough and it soaked the air filter, I didn't know what happened and thought I had blown the engine.
Then I decided to read the manual, duhhhhh ;-) ....Mike
   / To Screw, or Not To Screw.... #8
The motors I have seen with a fill hole like that (which includes several generators, as well as my tiller) all say to fill basically until the oil is about to spill out. No dipstick required.
I have to admit to being impressed.
An industry has managed to take something that was properly manfactured in my grandfather's day (that's going back a while !) and fubar it up nicely. :thumbsup:
That "update" dovetails nicely with people's skill sets today. The avg. consumer has next to no mechanical aptitude, esp. when compared to my father's generation and earlier.
Mikey - well, at least you figured it out, many people would not have. Good example of what can go wrong, with something that should be dead simple.
Generators are esp. irritating - when do most people try and fire 'em up ? After a hurricane, or some other disaster strikes.
Here's hoping that not many generators are out of action on the east coast this weekend, simply due to improper oiling !
Rgds, D.
   / To Screw, or Not To Screw.... #10
I have a briggs generator and a briggs engine on my Simplicity lawn tractor, both say to screw the dipsticks back in to check oil.
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
