To much oil on oilstick
   / To much oil on oilstick
I thought I would give an update, about 4 years later, on my diesel fluid in my oil, in case someone else has this problem. I have approximately 190 hours on tractor now. No problems at all, other than this. I never fixed anything to do with fuel in oil in all this time, I would just change the oil way more often than normal. I do not use my tractor very much. It was so easy to change the oil, and I always though it would be an injector problem. The last oil change only lasted about 10 hours between them, and the level moved a little ways up the dipstick quicker than normal. I never let it get very "diluted". I decided to change the $30.00 mechanical fuel pump when I changed the oil. That was the problem the whole time. Should have done it long ago. After it was out, I could hold the pump in my hand, add some fuel to it, push the plunger in and out a few times, a good amount of fuel would pass by the plunger and housing, going right into the oil pan. Guess it got worse over time.
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
