TO 30
   / TO 30 #11
I had a TO 30 Ferg once, for about 10 years. I 'tolerated' the 3pt on it (preferred the 8N Ford) because it didn't have position control. Either going up or going down. It did have a good draft control, if I remember right.
I always thought something was broken that the position control would not work. But learned when I tore it down that there was nothing inside that would feed the height of the arms back to the control valve. So, I made do and learned to live with it. When I 'moved up' to a Deere 420 two-cyl, I gave up some hp, but gained the position control in the 3pt, and had draft control too.
I really liked the TO 30 and hope you like yours as well.
   / TO 30 #12
Higgy: .... Yes ,I do cut firewood with the Ferguson (see attached).
It's nervous work, but have done it many years.
   / TO 30 #13
gonads /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
Dane
   / TO 30 #14
rdbrumfield: ...Thanks, I've owned her for about 25 yrs. and the paint is showing some wear, but still OK if it's clean. I think these are what you'll be looking for.( see attached )
   / TO 30
yes, that is exactly what I need. Hope to find some as I would like to get back up to looking new
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
Toro TRX-20 Walk Behind Trencher (A57453)
Toro TRX-20 Walk...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X6JD476305 (A57453)
2018 Peterbilt 389...
2159 (A58376)
2159 (A58376)
1703 (A58375)
1703 (A58375)
