Titan Pallet Forks
   / Titan Pallet Forks #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
   / Titan Pallet Forks #2
Yeah I bought some of the light weight ones this summer for my 2017 Kubota BX23s and have been satisfied with them. I don't use them much at all as I have the very handy Landpride small grapple. Shipped fast, picked up some small pallets of bricks and various other small tasks like moving my fuel transfer tank etc.
   / Titan Pallet Forks #3
I have a similar 'frame' (JDQA) that is a combination (or swap-able) pallet-fork or bale-spike.
For me, the bale-spikes are usually on.
I have a set of the JD forks with the round bar mount, but I need a set for another location where the second tractor is. These seemed like a cheap option since I have the forks if they hold up. The tractor only has the 300X loader, so I think it is limited to around 1300lbs.
   / Titan Pallet Forks #5
I have a set I have been using on my 4300 for many years and have never had a single issue with them.
   / Titan Pallet Forks #6
I bought the 4000 # version when I saw them online for $40 plus freight about a month ago. I have them on my JD310G. they work great for the couple of times I have used them, just have to make sure the clamps are tight.
I ended up buying these from amazon. Got here in a couple days. They seem strong enough. Pins lined up right, and the forks slid right on. Forks maybe a bit looser than others I have used, but will work for the lifting capacity of this tractor.
vergenes (A50657)
vergenes (A50657)
1262 (A50490)
1262 (A50490)
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
