Grapple Titan 48" JD quick attach grapple.
   / Titan 48" JD quick attach grapple. #1
dusty3030
Veteran Member
West TN
Kubota MX5400 Cab, Kioti NX6010 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
Picked it up yesterday at Titan warehouse in Collierville TN. Brandon was who I had spoken to on the phone and he loaded me up. Great to deal with and if you have an opportunity to go pick up in lieu of shipping I suggest you do it, it worked out well.
These babies were stacked to the ceiling as well as were the skid steer attach grapples.
Seems well built. Pivot points are greaseable pins.
Fit on a 400x loader perfectly.
Found the quick connects I needed at tractor supply for $20 for the set, hooray.
Finding a solution to get from the 1/2" pipe thread or the whatever the **** the hoses crimped on connector was to a 1/4" male to use the right pioneer coupler to hook up to deere's hardline kit is more challenging. I will post more on that at a later date. A hydraulic shop is going to be the best solution and I will post on that when I do the final fit, I used brass reduction fittings from Carquest for the short term cause that is all I could get on Memorial Day weekend round here.
I will wash the tractor and do better pics tomorrow.
Here is the grapple and the card on the pioneer couplers from TSC. Also included is a fine Kansas City Memorial Day weekend beverage.
   / Titan 48" JD quick attach grapple. #2
Lookin good, You think it might need a third tooth?
Haven't used it enough to know better, I have some stuff lined up so when it dries up a little I'm going to give it a workout.
   / Titan 48" JD quick attach grapple. #5
Nice root grapple and $20 a set of couplers ain't bad either. I just paid $150 for a set of flat faced couplers. Total for two 1/2" hoses 7' long for a new stump bucket grapple cost me $280 at the JD dealer.
   / Titan 48" JD quick attach grapple. #8
The only problem with your grapple is it looks a little green;). Actually it looks good, did you paint it or do they over it in colors other than black.
The JD quick attach grapples come from Titan in JD green.
   / Titan 48" JD quick attach grapple. #10
So how did your tractor handle this unit...?
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Misc. Commercial Kitchen Equipment (A50860)
Misc. Commercial...
Set of Gates (A50860)
