tired kubota clutch
   / tired kubota clutch #1
tractorboys2
hollis nh
my L3600 is geting tired . I think it needs a new clutch. it barely wants to go. im not afraid to undo every thing and do it my self. dont have a shop manul yet. sombody told me you break it in half. made it sound simple.how involved is this. anybody know what a new clutch cost? I did a few jeep clutches but not landscaper machine yet. thanks bill
   / tired kubota clutch #2
You have changed clutches so you will be fine... separate things and roll apart.
Remember to replace the pilot bearing.
& take pictures and post them... everyone likes to see the inside parts... KennyV
   / tired kubota clutch #3
If the Kub is like other tractors, splitting means supporting the front and rear halves, the front with a rolling dolley. The entire tractor comes apart, and the steering should be blocked so that you don't have any rude suprises. This can be dangerous if you aren't using your head, but is less hard than I thought it would be. You have to disconnect everything that connect the two halves of the tractor. Fuel lines, hydro, battery etc. Going back together can be irritating at times. You have to be well aligned, and may have to turn over the engine with a pry bar to get the splines to engage. We even turned over the pto to help. Like was said, if you have done clutches on vehicles, don't be afraid of this. Just be aware when supporting for rolling ahead.
   / tired kubota clutch #5
On my L3600 the clutch became where would not release when clutch went to floor. tried all known methods to release clutch then blocked rear under transmission. locked the front end so would not steer left or right. with hoist holding the front part removed the seperating bolts when front and rear was loose rolled the front forward found the throw out bearing yoke had came loose from dirt water crud on the spline to transmission. would not release because of this. cleaned reconnected the yoke to throw out bearing and reinstalled the housing clutch worked proper. App. 1200 hours on tractor. 4 hours of not hurried work. putting the sheet metal back on took longer.
maybe this will help
ken
ok i finaly did it. took it apart and found the problem. clutch was ok but the throw out bearing linkage big rod thing that goes through the housing was rusty inside. I removed it sanded it down lubed it up and reinstalled it. changed the bearing.:rolleyes:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2169 (A58376)
2169 (A58376)
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2356 (A58376)
2356 (A58376)
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2004 KENWORTH T800 HOT OIL UNIT (A58214)
2004 KENWORTH T800...
