tire - valve stem leak
   / tire - valve stem leak #21
Guess you don't want tubes in them, but the cost at this time is about $20 a tire. I guess the reason they make them tubeless is to save $20 a tire so they can charge us later to put it back. Unless you are worrying about that puppy running so fast that the tubes will get hot. /w3tcompact/icons/wink.gif /w3tcompact/icons/smile.gif
   / tire - valve stem leak #22
I don't know what size tire that's for, but radial tubes for a 17.5LR24 are $75 each. Ouch!
Mark
   / tire - valve stem leak #23
mark .. i'd hate to see what my back tire tubes are worth if those are worth $75 580/70r/38 (23.2/70r/38) and 480/70r/28 (19.2/70r/28) front
JD Kid
   / tire - valve stem leak #24
If your tires are radials, you'd better be sitting down if you ever need tubes. If they're bias ply tires, it shouldn't be nearly as bad.
Mark
   / tire - valve stem leak #25
Yep mark they are radials .i poped a front one on the case i used to have (7210)and for the tire it was around $1400 (USD700-750)what realy hurt was the tire only had done 1200 hr's the rear ones i have now would be around USD1000-1200 a tire :(
JD Kid
   / tire - valve stem leak #26
Mine are 16.9 - 30 rear and 9.5 - 24 fronts. They are bias type Ag tubeless Firestone tires.
   / tire - valve stem leak #27
That's steep. Mine are bad $600 each for the rears and $300 each for the fronts.
Mark
yep ... as was suggested, poor installation. They searched for quite awhile and found a tiny "puncture" in the tube ... and, of course lost all the CACL in the meantime.
I haven't picked it up yet so I don't know the $$damage$$ yet but I am getting tired of seeing the poor tractor on 3 legs so I guess I'd better get it picked up tomorrow. Can't have the 'bota sitting out the long weekend ...
too bad that common sense ain't
   / tire - valve stem leak #29
JD, I might suppose that the anti-freeze would be added to water to counteract the corrosive tendancy of water to cause metal to rust. Anti-Freeze has an anti-rust additive to it to prevent causing rust in your engines...thus possibly retarding the start of rust on your rims....but just a guess mind you.
2013 MAXX-D BUMPER PULL TRAILER (A58216)
2013 MAXX-D BUMPER...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2017 CATERPILLAR 930M WHEEL LOADER (A52709)
2017 CATERPILLAR...
JOHN DEERE 469 BALER (A58216)
JOHN DEERE 469...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
