Timing Belts: time limit spec
   / Timing Belts: time limit spec #41
What year CR-V did you replace the timing belt? My friend has a 2005 model with a timing chain and it is still humming along at 280k+.
I think some of the newer direct injected vehicles wear out timing chains due to oil dilution/lack of lubrication.
Can't remember but I will find out. That was only the second belt replaced and it has just shy of 300k on it. CJ
   / Timing Belts: time limit spec #43
Older Civics are spec'd by Honda as having a 7 year time limit on the Timing Belt.
Just curious what other interference-engine owners are seeing in their applications....
Rgds, D.
A few years ago had a customer come in with a Civic that according to the customer ( made a funny sound and wouldn't re start no matter how long they cranked it over)
I did a compression test - 0 psi on every cylinder.
Pulled the cam belt cover off and the belt was still on but missing several teeth. after head removal it was actually cheaper to buy a used head, because every valve was bent...
I would be nervous going 100k on a belt on an interference engine.
I see it as cheap insurance to change them a little early.
Almost no other item can do such massive damage in such short order.
I like my non interference- timing chained engines in this respect.
People's ignorance about Tbelts does work to the manufacturers advantage.
Might have been a Continental Tbelt kit a friend just put into his wife's car recently. A nice bright sticker was supplied, with engine appropriate adhesive on it. Great reminder, and good info for a subsequent buyer, if the belt change info is right there, when you open the hood.
Rgds, D.
   / Timing Belts: time limit spec #45
I just had the timing belt, water pump, idlers, cam seals, and belt tensioner replaced on my son's hyundai tiburon for $350 parts and labor. His manual stated interval was 60,000 miles.
That seems like a reasonable price, all-in.
Rgds, D.
   / Timing Belts: time limit spec #47
It is a 2001. The rust will get it before it breaks down! CJ
The Glass-Half-Full version of us living in the salt-belt ! :laughing:
Rgds, D.
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
