Timing Belts: time limit spec
   / Timing Belts: time limit spec #1
3930dave
Super Member
Canada
Ford 3930
Older Civics are spec'd by Honda as having a 7 year time limit on the Timing Belt.
Just curious what other interference-engine owners are seeing in their applications....
Rgds, D.
   / Timing Belts: time limit spec #2
Not a whole lot of experience with them but most seem to be either 100k or 120k miles maintenance items. When looking at used cars in that mileage category it's a big selling point if it's been changed.
It's not something to ignore for sure.
What most people look (hope) for in a used vehicle is low miles.
What I didn't realize until owning my first interference engine (I'll now get kicked out of the Real Men club :D) and reading the Owner's Manual is that there is a relatively short time spec.
On mine, the mileage could be deemed OK on the original belt, but since it was definitely Past Due on time, I changed it.
Our cold Winters tend to accelerate belt breakage.
Rgds, D.
   / Timing Belts: time limit spec #4
I have a 2005 Tundra. The timing belt is supposed to be changed at the earlier of 90K or five years. I held out, but relented at year eight and 60K.
Steve
   / Timing Belts: time limit spec #5
The newer Honda V6 applications have a 6 year 105K change interval. I believe that the colder environments are easier on the belt than the hot and dry areas.
   / Timing Belts: time limit spec #6
Change it. Its a $500 now or $5000 later type of deal.
Chris
   / Timing Belts: time limit spec #7
Steve
I also have a 2005 Tundra but didn't know about the time limit. I just changed mine at 93,000 miles and 9 years. Oops.
   / Timing Belts: time limit spec #8
I didn't either, but the Toyota service guys kept reminding when I took the truck in for service.
Steve
   / Timing Belts: time limit spec #9
Having changed a good number of belts in my day and seeing a good number of cars towed into the shop with a broken belt, I would say that it really depends. Older Toyota 2.2l and 3.0l motors I would not worry about time and honestly if it were my car I would run it a lot longer than they say you should. I saw very little failure on these motors and if it does break, it does not damage the motor. Interference Hondas on the other hand I would try and change them at a reasonable interval. Time does have some effect on the belt. I believe Honda states something like if operated under 0f or above 100f use severe service witch have a shorter mileage and time requirement. There are some cars such as some Kias and Hyundias that I would change before the interval as I see the belts fail prematurely from new. I have found that how many pulleys the belt is routed between and how sharp the bends as well as belt size and material all influence life. A standard transmission will also be harder on the belt.
   / Timing Belts: time limit spec #10
Steve
I'm thinking about not buying any more Toyota trucks that have a timing belt. My 2011 V8 is a chain timing gear. How do you feel about that?.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2006 Toyota RAV4 SUV (A50860)
2006 Toyota RAV4...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
UNUSED Portable Double Bathroom (A50860)
UNUSED Portable...
