Tilt Steering Wheel Frozen
   / Tilt Steering Wheel Frozen #11
NFG is an adjectival phrase used to describe a part that is no longer good for its intended purpose.
Actually, I would think "NFG" is an acronym, wouldn't you agree?
And, it may refer to a brand new part that isn't usable for it's intended purpose.
This is another military term (or acronym) since the military loves acronyms!!
   / Tilt Steering Wheel Frozen #12
I agree. You are correct, NFG is an acronym and it can apply to any obect, new or used. /w3tcompact/icons/smile.gif I was thinking of it being spelled out, then it would be a adjectival phrase. /w3tcompact/icons/wink.gif
   / Tilt Steering Wheel Frozen #13
Okay, first I have to apologize for using a saying / adjectival phrase / acronym whose meaning I assumed was more generally known than apparently it is!
NFG - whatever it's language structure, means "Non Functioning Goods" however is more commonly lengthened to its vernacular slang definition of "No F****** Good"! One of those slang things that is OK to use in public but you know what it really means!
Kinda like one of my favorite old military sayings -- SNAFU! Of course SNAFU is actually a nounal phrase rather than an adjectival phrase!
And dey taught wese peeple only new tracters!!
Steve
   / Tilt Steering Wheel Frozen #14
Oops! Sorry to make this another entry but -- I would still love to hear from anyone who has comments on my NFG extending steering column. Still snafu. Thanks, Steve
My dealer gave me a can of Titanium spray to keep the cylinder moisture free...So far it is working..
   / Tilt Steering Wheel Frozen #16
<font color=blue>comments on my NFG extending steering column...</font color=blue>
I've got the same problem with my extending steering column. It's locked in place, and I can't budge it. I have not tried to force it with a wrench, since it's at a pretty good height for me... I'm afraid if I really crank on it, it will let loose and not lock back in position again...
Let me know if you find anything out, and I'll do the same next time I need service.
BTW... I also had some trouble with the tilt mechanism sticking, but it seems to work ok now.
John Mc
Hi John,
The Titanium spray lubricant my dealer gave me, solved the problem..But, he also told me that NH is sending out bulletins to dealers re; this problem. He has ordered me a new cylinder...Your's may have a bit of moisture in it like mine.
   / Tilt Steering Wheel Frozen #18
Yes indeed, that is just one of the problems I had with my TC/29D. I should have known it was going to happen, when I tried one out at the dealer absolutely every one on his outside lot did NOT work. I freed mine up with a can of N/H penetrating oil. There is a small tit that extends from the end of the tilt cylinder that rusts into position. You should notice the activator lever becoming a bit stiff right before it sticks for good, give it a shot of oil. If you have super steer like mine was, they have to half disassemble the tractor to replace it, which means a haul to the dealer.
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58216)
2012 TOP HAT...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
