Phred
Veteran Member
Guys,
Well I finally broke down and added a tilt meter. Actually I added two; one for side to side and one for front to back tilt. Should have done so long ago since much of my property is very steep.
I turns out the slopes that made me nervous (across slope) were only 10 degrees. As a result, I tended to be very conservative since the idea of flipping over one of these expensive machines is not very attractive to say the least.
The slopes tend to create run off that will create small "ditches". Hide one of these ditches/ruts under 6 ft tall brush and you have a problem.
The tilt meter and low gear makes a big difference. I highly recommend these meters.
Fred
Fred
