GeneD14
Veteran Member
- Joined
- Jul 29, 2003
- Messages
- 1,458
- Location
- Tennessee
- Tractor
- Kubota B26 TLB, Allis Chalmers D17 series IV, Kubota ZG-23 Mower, Kubota ZD 1211, Kawasaki Mule 610, Stihl 361, Stihl 045 AV Super, and a Stihl 660 Ported and tuned
flusher said:I have a 4-ft Yanmar RS1200 rototiller for my 21-hp Kubota B7510HST. Since the tiller doesn't appear to have a shear pin anywhere, I bought one of those Weasler slip clutches. Here's the info I received on adjusting the clutch:
The clutch has a series of exposed springs around the outside, to adjust the torque setting of the clutch, you need to turn each bolt on the springs the same number of rotations to keep an even pressure all the way around the clutch. Turning the bolts to compress the spring will increase the torque setting, and turning to expand the springs will decrease the torque setting. The clutch is shipped from us preset at 8,000 in-lbs setting. If you turn the springs down to the point they are fully compressed, then the clutch will not slip giving you no protection.
Looks like your slip clutch is a little tight. I'd check the spring compression closely and then consult the manufacturer about adjusting it, assuming the instructions that came with the tiller are not adequate. CCM probably is the place to start.
Ray,
Thanks for the info. When I bought the tiller I assumed that it was pre-set at the factory. Shame on me, I should have checked it. The next time I have a job for the tiller I am going to adjust the bolts like you mentioned.
