tie log splitter into hydraulics on 580c case backhoe
   / tie log splitter into hydraulics on 580c case backhoe #1
coltcc545
Howell, Michigan
580c case backhoe, jd 1020, david brown 995
hi all, i am looking into hooking up a 3 pt log splitter into my 580c backhoe(my other tractors listed are at our deer camp up north).
i see on the loader valve there are tees already installed, 1 is on the supply coming into the valve and it looks like 1 is on the return side.
these are all factory tees.(must be there for a reason) Would this be the proper point to tie in?
These valves must be closed valves (loader valve and backhoe valve) inorder for pressure to get to each valve i think. If so then tying into the provided tee should supply the needed pressure.
And i have the ability to change the log splitter valve to a open center or closed center, would i want closed center?
thanks in advance
Chris
   / tie log splitter into hydraulics on 580c case backhoe #2
Welcome to TBN Chris:D
Sounds like you have a good plan, your system should be CC, so adding Tee's and a new CC valve should be no problem.
   / tie log splitter into hydraulics on 580c case backhoe #3
thanks in advance
Chris
Chris,
your 580C is an open center system and you can not just tee into the lines.
Roy
   / tie log splitter into hydraulics on 580c case backhoe #4
Chris,
Roy
You sure? What about the "factory" Tee's?
   / tie log splitter into hydraulics on 580c case backhoe #5
Maybe they are pressure gauge check points......what size are the tee's??
Would be nice with some pictures....OP?
   / tie log splitter into hydraulics on 580c case backhoe #6
Ken,
this information is from a fellow employee that worked at Case in their Hoe division for 20 some odd years. His best guess was this was a mid 70's early 80's model.
I am with AKKA that they are probly test ports.
Roy
   / tie log splitter into hydraulics on 580c case backhoe #8
Wow, that is a good idea.. I wonder if this technique would work with a smaller backhoe? I can't see why not... I wonder if there is any plans to make the metal splitter on the stablizer arm?
Tim
   / tie log splitter into hydraulics on 580c case backhoe #9
Ken,
Roy
OK, I got it...They way I read is description-it sounded to me like the backhoe and FEL valve where Tee'd together, so I ASSumed it was a CC system, also a lot of real construction grade equipment is CC.
   / tie log splitter into hydraulics on 580c case backhoe #10
Ken,
agree 100% on construction equipment being CC and or LS. That is why I asked the man that knows.
Roy
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
UNUSED 2-Pack Yellow Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
71053 (A49346)
71053 (A49346)
