thumb for Kubota B21 w BT751 hoe
   / thumb for Kubota B21 w BT751 hoe
If you do straight linkage only thing to fabricate is the base cyl mount which is easy with the tools you have.
For you is easy . . . to misquote Senor Wences . . .
Actually, I may have a metal working lathe. Long story of hand me downs, but I think I have it stored in the barn. Haven't thought about it in a while.
If you had to do it over again, would you weld it on instead of using all those bolts? Or some similar load spreading deal?
   / thumb for Kubota B21 w BT751 hoe #12
I would do the same. The girdle is kinda ugly but it cannot bend the stick, loosen or shift anywhere. At the time there was a thread or two about guys bending their sticks with weld on thumbs. I decided to be super cautious. Maybe a long (12-14") doubler plate welded to the bottom of the stick and under the cyl mount would work fine though.
   / thumb for Kubota B21 w BT751 hoe #13
Does anyone have pictures of the Titan bolt on thumb attached to their bt751?
Deer Target (A57149)
2012 John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
2012 John Deere...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
1770 (A58375)
1770 (A58375)
DRAGON 500 BBL FRAC TANK (A58216)
DRAGON 500 BBL...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
