Throttle control on a TC25D
   / Throttle control on a TC25D #1
mandor
Canadice , NY
New Holland / TC25D
Hello all. I am a new owner of a TC25D and am enjoying all the work I can accomplish with it. Now that it has 160 hours I am noticing the throttle control tends to work it's way down. I read in a earlier posting that someone had adjusted theirs. I am wondering if you needed to remove the whole plastic dash to get at the adjustment. Thanks for any help in this. I can probabily take it to the dealer but know I will end up adjusting it later on my own anyway.
   / Throttle control on a TC25D #2
Here's a link with the instructions.
Thanks for the link. That helps and I will adjust it tonight.
Mandor
   / Throttle control on a TC25D #4
I have a TC25D and just tore down that hole area to replace the tilt steering shock.
To get to the throttle "friction disk" - simply remove the two bolts that hold the black plastic together below your tilt lever and also after raising the hood you will see about 4 more bolts that need to be removed to take the whole black section off the tractor. At this point you can easily get to the adjustment.
You would not have to remove the instrument cluster.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2017 Ford Expedition Limited SUV (A56859)
2017 Ford...
40' FLATBED TRAILER (A58374)
40' FLATBED...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
