Thoughts on Chevy Colorado or Ford Ranger
   / Thoughts on Chevy Colorado or Ford Ranger #71
What was the full sized truck which got 22 mph? Was it 4wd? We’ve run GMs for years but have been switching over to Tundras. 18 mpg is all that I have ever gotten, and that was rare. The Tundras are worse.
I can get 23 easily with my Colorado, and that’s with 10 ply tires.
My 2016 F150 Supercab, 4x4, with the 3.5 Ecoboost will easily exceed 22 mpg if I don't drive too aggressively.
Note that it could have gone over 800 miles on that tank (36 gallon). Being honest, though...over 71,000 miles on the truck now and the overall fuel mileage since new, hand calculated, is 20.5 mpg. But that includes a lot of miles towing AND on LT-E tires.
   / Thoughts on Chevy Colorado or Ford Ranger #72
I have been thinking about one of those for my next truck. There are a lot of advantages it the smaller platform though, especially when off the tar. Plus as some have mentioned in other threads, a small truck now is about the same size as an F150 30 years ago. Plus the payload and towing capacity are as good or better.
I’m a bit put off by GM right now but had hoped to keep my Colorado, and pick up an F250 or Ram 2500 next year for towing, plowing and to add a dump body.
   / Thoughts on Chevy Colorado or Ford Ranger #73
We test drove the 150 around town and thought it was awful. Just to big to drive on daily bases..
   / Thoughts on Chevy Colorado or Ford Ranger #74
Today I made a wrong turn and had to turn around. With my Colorado it would have been an easy illegal u-turn. Instead it was an illegal K-turn, which took longer to execute.
There is about a 1500 lb difference between the two trucks. Plus the difference in dimensions. That makes a big difference when driving down a marginal road, and it’s considerably easier to pull the small truck out of the mud if I do mess up. So far my Colorado hasn’t been badly stuck, but when I had my ‘04 Ranger I sometimes used it when my company Sierra was too big to go down a grown in road.
   / Thoughts on Chevy Colorado or Ford Ranger #75
Just like everything else in life, buying a truck is a compromise. We thought driving a full size truck on narrow roads or in town was a pain in the (*^%!. We found the new ranger could tow enough, get good fuel mileage, was comfortable to drive for the passengers and in town. Is still good after 40K of miles. (y)
   / Thoughts on Chevy Colorado or Ford Ranger #76
The nice thing is that there are so many options people can pick from. Everything from the Maverick size to big HD trucks. People can buy what they want and even choose the color! Good times!
   / Thoughts on Chevy Colorado or Ford Ranger #77
I wanted a Maverick, but my wife said I had to buy the F350. 😢
I folded my passenger mirror in with an ATM the other day, so that was nice. It was not on purpose. 🤣
   / Thoughts on Chevy Colorado or Ford Ranger #78
For those not needing a heavy duty truck I'd recommend at least test driving a Ridgeline. LOL and before everyone chimes in "but it's not a real truck" I know what it is and isn't. If you will need your truck to do the following, a Ridgeline won't be a good choice.
1) Do a lot of 4,000 plus pound towing. Ridgeline is rated to tow up to 5,000# so great for small trailers with your lawn tractor, SXS, motorcycles, light camper, etc. If I needed to tow 5,000+ pound trailer I'd probably go 1/2 ton but some configurations of Ranger and Colorado are rated to tow up to 6,000-7,000.
2) Take your truck off-roading, rock crawling, mud bogging, etc. Ridgeline doesn't have enough ground clearance for that, no low range, and the AWD system isn't designed for doing a lot of this.
I have 2 trailers both aluminum, an open motorcycle and a 6x12' box, so Ridgeline is more than capable for them. I'm on my 2nd Ridgeline, having bought a 2023 last December, and I'm not subjecting my $40,000 truck to rock crawling or banging it through the woods. I have a couple SXS's for that anyway.
I use the bed for hauling firewood, bags of garbage to the dumpster every 2-3 weeks, 5 gallon cans of gasoline and diesel, light motorcycles, stuff from Lowes, etc.,
When I was looking to replace my 2018 Ridgeline I looked at GM's new Canyon/Colorado that was just coming out as well as Nissan's new Frontier. (The newer 1/2 ton trucks, as others have commented, are simply too wide and large for many of the roads I drive on and spaces I park in.) The more I looked the more things I liked about the Ridgeline. First off the bed, while only 5'-3" long, is wider than other mid-size trucks with over 4' between the low wheel wells. Reaching over to access items in the bed is also fairly easy.
The rear seats are wide open underneath which is convenient to slide a rifle case, golf clubs, etc. under. Or they individually fold completely up out of the way against the seat back which provides a lot of space. I can fit my bicycle back there. Also the back seats are quite comfortable. The front seats are large, supportive, and *very* comfortable. After driving a Silverado 1500 for a week I couldn't wait to get back in my Ridgeline. The Silverado seats were fairly large but had very little support.
Handling and ride: there's just no comparison between the other midsize trucks I've driven and Ridgeline. Which is to be expected with Ridgeline's fully independent suspension, it handles like a nice car instead of a truck. In the above mentioned Silverado when were were on gravel roads with washboard surfaces that truck had a jarring ride and the back end was hopping and sliding wide on corners. My friends Tacoma is even worse in this regard.
When it comes to the 4wd system Ridgeline utilizes AWD, actually Accura's torque vectoring SHAWD and I can say on the dirt and gravel roads I often drive on, as well as snow and ice covered roads, it works better than any 4WD system I've used.
I almost forgot to mention the large, weather-tight trunk under the back of the bed which I don't know how I'd get along without now? The spare is also located inside that compartment rather than hanging outside under the back of the truck.
   / Thoughts on Chevy Colorado or Ford Ranger #79
One man's awful is another man's good time, lol; I love the ridiculousness of my truck. It is too big, but I'm too big; we're similar in spirit. 🤣
Milo just mentioned the Ridgeline; those are real nice, provided they're workable for what the buyer wants they're a great option.
Hell, if you're looking for something useful and fun a Subaru Baja is a good time, too. Though they're a little long in the tooth these days.
   / Thoughts on Chevy Colorado or Ford Ranger #80
I've got a half ton Silverado with the 5.3 V8, 4WD, and on a trip I can get 22 or slightly over, 21 is pretty easy to get just driving around, but I'm an easy driver too.
Before I bought this pu, I would have never believed that a full size pu with a decent powered V8 would get over 20 mpg.
SR
It’s the 8+ speed transmission.
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
(UNUSED) WESTERNDORF 4200 BRUSH CRUSHER GRAPPLE (A52708)
(UNUSED)...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2024 John Deere 331G Skid Steer w/ WARRANTY! (A59213)
2024 John Deere...
