Price Check third function.
   / third function.
Hey guys while we r kinda on the subject, would a diverter valve have enough flow to run a hyd. post hole auger? Or is that where the true third function is better? Or would either be just fine? :confused3:
That is a good question surely someone knows?
   / third function. #22
Some people are not handy or knowledgeable and want someone to make up a kit exactly for their tractor, and if they want to spend that kind of money, then so be it.
I just can not see the money in the kits.
I added rear hydraulics with the JD kit for my tractor specifically because I'm not up to speed on hydraulics. I'm still a hydro newbie, but I've been reading the Vickers Hydraulics manual and looking forward to the next project.
I would like to use the rear controls for top 'n' tilt and add a 3rd function for a grapple. I would love to save some $ and buy parts, rather than a 3rd function kit. Anyone know of a parts list, DIY blogs, etc. for adding a 3rd function from parts rather than a kit?
   / third function. #23
Say you have 11.8 GPM and an 18 in shaft on a 3 in cyl on the grapple.
The extend speed would be about 2.83 sec, and retract would be about 2.14 sec. That is fairly quick.
Well, 1 of 2 possibilities:
1. The Kubota 3rd function kit I had included a hidden flow restriction.
2. This isn't an issue in practice.
The grapple function never worked faster than I could handle. Now, realize I was using a GST tractor. I rarely set the rpm very high and used the foot throttle to maneuver the tractor and speed up the hydraulics when necessary.
ac
   / third function. #24
The one problem with your calcs is that as far as I know of anyway, :confused3: no grapple uses 3" dia cylinders. Smaller dia cylinders are normally used and so the movement should be quite a bit faster. (I think) :eek:
I agree, I used that example as the extreme. And yes, it would be faster.
Don't know why avc8130 grapple was slow.
Cylinder Speed single cyl
Bore Size 2 inches
Rod Diameter 1 inches
Pump Flow 11.8 GPM
Extension Speed 14.5 inches per second = 1.25 sec
Retraction Speed 19.3 inches per second = .93 sec
   / third function. #25
Chickengrower,
If the valve is sized for the flow in GPM, any type valve will run the auger.
You can use a selector valve, a true 3d function, or remote valve.
   / third function. #26
3ed function parts for grapple
Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
Selector/diverter valve for grapple.
Surplus Center - 12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
http://www.surpluscenter.com/Instruct/I9-7852.pdf
Plus hoses, wire and switches.
   / third function. #27
Thanks JJ! You da man! :thumbsup::wave:
   / third function. #28
Bore Size 2 inches
Pump Flow 11.8 GPM
JJ,
I can't argue with the math, it is sound. Again, I didn't usually run the grapple at full rpm. I also had 2 cylinders on my grapple.
It could also be noted that Everything Attachments, WR Long and Kubota all sell 3rd function kits. I don't believe ANY of them have any flow restriction. Lots of happy users on these forums and I don't see anyone complaining about how fast their grapples operate.
ac
   / third function. #29
   / third function. #30
2014 Ford Taurus Sedan (A55853)
2014 Ford Taurus...
AGT PD-680-PZ Quick Attach Hydraulic Hammer (A56469)
AGT PD-680-PZ...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2005 Freightliner Sportcoach Elite MH401TS 40ft. Class A Motorhome (A55853)
2005 Freightliner...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
